It would appear that the same question pops up every time a new higher resolution sensor is announced: "Will my lenses be sharp enough for an X megapixel sensor?"
I was curious to see exactly what happens when the lens is much sharper than the sensor, so I set up an experiment. The idea is to select a sharp lens using a D7000 body, and then evaluate the performance of the lens on a lower resolution body, a D40 in this case.
First, I took my sharpest lens, a Sigma 17-50 mm f/2.8. At 35 mm f/5, this lens can resolve more than 60 line pairs per mm in the centre, which is a bit better than the Nikkor 35 mm f/1.8 prime (about 57 lp/mm in the centre). It is possible that this lens is even sharper than that, but as you will see, the D7000 sensor may be the limiting factor.
To construct a high quality, high-contrast straight edge I took a normal razor blade (2-sided variety), and blackened it with candle soot. The blade was mounted on a sheet of white paper (high quality, not normal copier paper). The camera was positioned at a distance of about 1.4 m from the target, to ensure we are in the "sweet spot" of lens performance. A flash was used to ensure maximum contrast. Here is what the raw Bayer image data from the D7000 looks like (upscaled for display)
On the D7000, focus was performed with LiveView, and the sharpest shot of a sequence was selected. On the D40, I started with AF, and then bracketed focus manually, again selecting the sharpest shot from the sequence.
Before we look at the details of the curve shapes, first some justification: I do not have the equipment to measure if the Sigma lens is diffraction limited, but if I can measure an MTF50 of 60 lp/mm on a D7000 sensor, then I should be safe on the D40 sensor, which has a theoretical Nyquist limit of 64 lp/mm. I have thus assumed that lens resolution is not the limiting factor for the D40, i.e., that the MTF curve we measure is really the D40 AA filter MTF curve.
The razor edge was then processed with MTF Mapper to extract MTF curves of the green photosites (i.e., no demosaicing was applied, no interpolation, just the raw green photosite data). Plotting the MTF curves in cycles per pixel gives us the following:
The red curve (which looks like a straight line here) is the diffraction-limited MTF curve for the selected aperture (f/5), plotted against the scale of the D40 pixels (7.8 micron). The real diffraction-limit MTF is independent of pixel size, but because the plots are in terms of cycles per pixel, the diffraction curve would be "lower" (i.e., steeper slope) if we plotted it for the D7000 pixel pitch (not shown). The diffraction limit is the absolute physical upper resolution limit imposed by the lens aperture.
The orange curve is the measured MTF curve for the D40. The dashed blue curve is the MTF curve of a Gaussian blur kernel with the same MTF50 value as the D40 curve, i.e., 0.294 cycles/pixel. The D40 curve is quite close to the Gaussian, which would mean that sharpening the D40 image with an inverse Gaussian, i.e., Richardson-Lucy (RL) deconvolution such as implemented in RawTherapee, is a really good match for the D40.
The black curve is the measured MTF curve for the D7000. This curve is quite different from the D40 curve. There are two possible explanations: either the D7000 AA filter has a different MTF curve shape (compared to D40), or the lens is not quite sharp enough to reveal the sensor AA filter MTF completely. I suspect the latter is more likely. At any rate, the interesting thing here is that the contrast is much lower than the D40 at around 0.15 cycles per pixel. In other words, per-pixel microcontrast may appear lower than the D40, but this will probably be rather subtle because the MTF50 values are so close, which can be observed at around 0.29 cycles per pixel.
That wraps it up for comparing per-pixel sharpness (which would be analogous to comparing 100% crops for sharpness). What about real-world sharpness? We can plot the same data on a line pairs per mm scale:
Here we can see that the D7000 performs much better than the D40. The measured MTF50 values are 60.47 lp/mm for the D7000, vs 37.64 for the D40. The D7000 thus captures images that are sharper by a factor of 1.61 than the D40. Now for the punchline: the linear increase in resolution going from the D40 to the D7000 is 1.649 (7.8 micron pixels vs 4.73 micron pixels). From this, I deduce that the Sigma 17-50 mm f/2.8 lens is sharper than the D7000 sensor. This is of course only in the centre of the lens. This is further corroborated by Sigma's published MTF curve for this lens. They claim roughly 0.9 contrast at 30 lp/mm, I measured 0.77 on the D7000, and 0.63 on the D40 at 30 lp/mm.
The other feature that I would like to point out is the contrast at 40 lp/mm. The D7000 obtains a contrast value of 0.68, D40 only 0.46, thus the D7000 manages to pull out about 49% more contrast at that resolution. This will produce a lot more "pop" at 6x9 print scales.
Lastly, my take on the Nikon AA filters: It would appear that the D40 AA filter has an MTF50 of around 0.3 cycles per pixel (allowing for experimental error), which produces a blur that is very close in shape to a Gaussian. This seems to put the effective resolution of the D40 at about 60% of the resolution implied by the pixel pitch, which is lower than the 70% figure often quoted for sensors with Bayer and AA filters. The D7000 seems to be heading in the same direction, i.e., an MTF50 of 0.3 cycles/pixel, or a peak resolution of about 63.4 lp/mm.
Norman Koren stated that 0.33 cycles per pixel is "pretty decent for digital cameras" (http://www.imatest.com/guides/modules/sfr/). He must have been referring to Canon bodies
Now for the bad news: The phase-detection AF module on the D7000 is probably designed for a circle of confusion of about 0.02 mm, or equivalently, a resolution of 36 lp/mm. This means that the AF module will say that your focus is acceptable when the area under the AF reticule has a sharpness of 36 lp/mm or better. In the worst case scenario your "in focus" point will be at a resolution of 36 lp/mm, and some other part of your shot will be at 60 lp/mm. Which explains why I only started worrying about AF accuracy when I got my D7000 --- the D40 would never reproduce any area at a resolution sharper than 37 lp/mm (from results above), so your entire DoF region would be at the same sharpness level, provided the lens was sharper than 37 lp/mm. Fortunately, this problem is easily avoided by not worrying about it, mostly because it is clearly visible at 100 crop views, but not likely to be obvious in an 8x10 print.
