LG G3 Battery Issue
Surely that keep awake is a problem?
Yes that looks suspect. Here is mine, left the charger at 9 this morning.
Okay, so I've done a factory reset, and it seems to be much better! I will continue to monitor... #touchwood
Hi
Just got a G3 this week and finding the battery drains quickly.
Been looking around for solutions, so without an update from LG, this may be my only solution,
http://www.ebay.com/itm/3500mAh-Exte...item3cff653cce
Sorry but not sure how ordering from overseas works? need to do homework on that....I see customs is a headache. And how do we check if the extended battery is compatible with our phones?
Hi
Give it a few days, it sorts itself out most of the time
Zertop, you're right i should give it a few days first and then see how long the battery lasts.
