Posted by: beemerstyle
Description: These are Shop Demo Units (never been used/opperated) supplied with a full 12 month guarantee 2 units available 1 x white & 1 x black Product Description The Worlds First HD Wall-Mounted Projector HD Ready Front Projector With HDMI,Wall Mountable HD Ready Projector with XD Engine Technology. Available in Black or White. Features: - HD Ready - High Definition Multimedia Interface (HDMI) - Wall/Desktop Mountable with brackets/stand (optional) - W-XGA Native Resolution 1280 x 768 - Very Bright 1000 Lumens - Contrast Ratio >2500:1 - Composite, S-Video, Component, VGA, and HDMI Inputs - Includes Remote Control -Worlds First Wall-Mount Projector -Worlds Best Design Superb Picture Quality: - XD Engine - HD ready - 0.65" DMD, WXGA(1280 x 768) - 1000 ANSI Lumen - 2500 : 1 Contrast Ratio Incredible Performance: - Lamp Life Time 4000 Hours - Extremely Low Noise 24dB - Auto Zoom and Focus - Vertical Lens Shift - HDMI Specifications: - Projection System DLPTM (0.65"" DMD) - Resolution Native : WXGA (1280x768) Max : SXGA (1400x1050) - Aspect Ratio Correction Native 16:9, Support 4:3 - Brightness 1000 - Contrast Ration (FOFO) 2500:1 - Uniformorty (min) > 98% - Noise Normal/Silent : 28dB / 24dB - Colour Wheel 6 Segment (R/G/B/R/G/B) - Projection Lens Focal Length : 24.3mm ~ 34mm Zoom Style : Motorised Auto (1.42X) - Projection Image Screen Size : 30" ~ 300" Standard : 3.8m ~ 5.3m @ 100" (Wide) - Lamp Type NSH 200W - Lamp Life Normal : 4000 hr Economic : 6000 hr - Dimension (mm) 443 x 254.2 x 92.2 mm - Weight 4.5Kg - Video Compatiability NTSC / PAL / SECOM / NTSC4.43 / PAL-M / PAL-N - HD Ready 1080i / 720p / 576P / 576i / 480p / 480i - OSD Language Korean / English / French / Spanish / German / Portugese / Swedish / Italian / Chinese simplified - Power Consumption 280W - Power Supply AC 100 ~ 240V (Free Voltage), 50Hz/60Hz - Sound x A/V Input/Output S-Video : O Component : x Composite : Yes (RCA-to-Dsub Cable) Digital Input : Composite Video (RCA x 1) IR Port : O Sound L/R : x
Price: R4800.00
LG Projector (AN110B) World's first wall-mounted projector
