LG Wall Mounted Projector
by: mrminds
Description: LG Projector AN110w-JD• Worlds First Wall Mountable Design • HD Ready • High Definition Multimedia Interface (HDMI) • Wall/Desktop Mountable with brackets/stand (included) • Very Bright 1000 Lumens • Wide-XGA(1280 x 768) / 0.65" DMDx1 • 1000ANSI Lumen Brightness • Contrast Ratio: 2500 : 1 • 4000hrs Lamp life time • Extremely Low Noise 24dB • Vertical Lens Shift 125% • Vertical Keystone: Right/Left Separated Keystone • Motorized Zoom(x 1.42) & Focus • Auto Lens Shutter & Ventilation system • Compatibility HDMI with HDCP • Weight: 4.5kg • Dimension(WxDxH): 443 x 92.2 x 254.2(mm)
by: mrminds
