leon.davibe
- Feb 3, 2009
People all seem to want a manual or supplier to tell them their specific device is compatible with a lithium lifep04 battery
no supplier will tell you this
they will happily want to sell you a replacement device
TLDR you can use a lifep04 in any device that had a lead acid battery it can't damage the battery
it is as easy as pie , just connect it you don't have to change anything
Some caveats
UPSs with 7ah batteries
Hard to find the form factor with a bms to meet the load of inverter if load fits you can use it
And 48v systems batteries come in two sizes
16s/51.2v nominal is a perfect fit (either 4*12.8v or a 51.2v pack)
15S /48v nominal not so much (if settings can be changed to it's range you can use it, though i would rather go for 16S for standard overcharge protection at 60v on certain devices as the 16s layout @ 3.75v lands you there)
The voltages of lead acid devices, top bottom float etc all work perfect with lifep04, Thanks to the 3.2v cells that can make up exact matches
a lithium battery
comes with a BMS (battery management system)
that will separate the cell from the charge current/load the moment the upper or lower voltages are hit
it is almost impossible to overcharge/over discharge a lithium battery
as long as you don't bypass the BMS or it fails
or you have a problem battery (badly matched cells)
these items will give problems eventually
irrespective of device you connect it to
Edit
If the device has silly fan controller or algo that doesn't keep the fan running until the battery is fully charged, maybe ad a fan that spins all the time
Some devices charger aren't really engineered to cope with the amps for extended periods of time , and since lithium soaks up charge it may work harder than it would on lead acid
So maybe the extra fan is complulsory
Some caveats
a lithium battery
Edit
