Saint_Technika
I'd like to know whether lightweight distros like slitaz do have as many packages as the likes of ubuntu or does one have to go back in time to earlier ubuntu distros for old hardware?
Ubuntu Desktop Edition
700 MHz processor (about Intel Celeron or better)
512 MiB RAM (system memory)
5 GB of hard-drive space (or USB stick, memory card or external drive but see LiveCD for an alternative approach)
VGA capable of 1024x768 screen resolution
Either a CD/DVD drive or a USB port for the installer media
Internet access is helpful
I don't know what apps you need, but if you want something really light:
http://www.damnsmalllinux.org/
gimp is relatively heavy in my experience.Mostly educational: Kiwix + wikipedia, klavaro, marble, sagemath, python, okular, calibre, shutter, gimp, pidgin
http://antix.mepis.org/index.php?title=Main_Page will blow your dsl out the water for lightness any day!I don't know what apps you need, but if you want something really light:
Template: debconf/priority
Value: high
Owners: debconf
Value: critical
Owners: debconf
Two questions:
1. Define lightweight? Do you mean something that comes with a featureless window manager and a small number of packages? Or a distro with only the bare essentials compiled in?
2. Does it matter how few packages a distro offer if it offers everything you need?
FWIW, Debian - even in its current version - has always kept things light. Packages are compiled with various options, but split so that you don't have to install everything and the kitchen sink. You can change the behaviour of apt to not installe recommended packages but only required ones [1] for dependencies, keeping things quite small. It practically every window manager you can think of - from twm to KDE and everything in-between.
[1] Edit the following block in /var/cache/debconf/config.dat
Code:Name: debconf/priority Template: debconf/priority Value: high Owners: debconf
as follows:
Code:Name: debconf/priority Template: debconf/priority Value: critical Owners: debconf
Do this on a fresh minimal install, then apt-get update and be on your way.
A lightweight Linux distribution is a Linux distribution that uses relatively few resources, which may result in performance improvements especially on old computers with slower CPUs and less RAM.
I see your Gentoo and I raise you, Suicide Linux or Linux From Scratch![]()
Puppy Linux
