Linksys 3G router setup problem
antonbijl
Centurion
Not sure if this maybe belongs in the "general hardware" section, but here goes...
Recently got a 3G datacard (+HSDPA) and it's been working ok from my laptop.
Now invested in a Linksys 3G router (model WRT54G3G), but having problems with the installation.
Upon opening the box, I followed instructions to the letter (there are about 4 different stickers all very clearly indicating to install from the CD first). So I put the CD in and went through the installation steps (which are extremely detailed) exactly. Only problem is, when it gets to a certain point, it says something like "now checking you PC setup" and then displays an error message to the effect that the 3G datacard could not be found and I need to insert it into the slot in the router (except, I had already done this as directed by one of the previous steps).
So I've played around with it a bit. Pressed reset, rebooted it. Tried various combinations like putting the datacard in before switching the power on vs after switching it on etc. etc. Generally, When I plug the card into the slot the LED lights up (white), then briefly flashes green once, then goes red for a few seconds and finally starts flickering red. I can't remember how, but I definitely remember that on trying some combination of switching on/inserting/removing the datacard and resetting it also flashed blue sometimes. So the card definitely seems to "know" it's in the router, but no matter what I do the router doesn't seem to pick up the datacard.
Next, I called the Linksys tech support. Rather ironically, despite the gazillion warnings on the box telling you to first install from the CD, the first thing the tech support tells you is to "remove the CD from your computer". Mmmm
Anyway, they directed me to the web-based setup tool (which I had actually already stumbled upon).
Then as soon as we started going through this and got to the 3G network page, I asked the tech support if I can change the network from Vodafone UK to Vodacom SA. Did this and then of course the lady realised that I'm calling from SA and insisted that I call my service provider, because they only know what the settings should be for the UK not for South Africa.
I'm sure she's just wasting my time, because as I very clearly explained to her the datacard and the router don't seem to be communicating at all and surely this has nothing to do with the service provider. But she insisted that I must get this info first.
So I have a few questions.
Firstly, can anyone tell me what settings I should input (fields I want to check at present are host name, domain name (although these are indicated as being optional, but may be required by some SP's), APN name (currently "internet"), username and password (for APN).
Secondly, any suggestions as to how to get the thing to work. I'm guessing the firmware might not yet be compatible with the latest data cards, but this is really a wild guess and I haven't as yet been able to locate any firmware upgrades for this router on the www.
Thanks in advance.
AFAIK, the firmware for the router only supports 3G cards for now, not HSDPA enabled cards yet - well mine does ;) ... they promised a firmwire update in June though that would have HSDPA support.
Ok, I've picked that up from a few other sources in the mean time too.
What I'm not absolutely clear on is: Does that mean you simply cannot use the router with an HSDPA-enabled card, or should it work (but only "regular" 3G speed not HSDPA enabled obviously)?
If it's the first option, then I guess I'll just have to wait patiently until June, but if it's the second option then it rather looks like the router is faulty and I should probably return it.
BTW, datacard is a Merlin U740
Busy downloading latest firmware from Linksys now, although I'm not very optimistic this will make any difference
Mmm, should have spotted this faq on the Vodacom website before:
Are the 3G Routers compatible with the 3G HSDPA cards?
Yes the existing Linksys Routers are compatible however a firmware upgrade to the router will have to be done. The upgraded firmware will be available by the 1st of June 2006 on www.vodacom.co.za
Well, "by the 1st of June" could mean it will actually be available before then, but that would be naive I guess.
Ok, the latest version of the firmware (as available from linksys) seems to be 1.99.7 and that's what's installed on the router anyway.
So it looks like I just have to wait for a few weeks.
I would have thought there would be some backwards compatibility though. Surely you should be able to use the HSDPA-enabled card in the router even if you can't use HSDPA...
I can understand it, but I don't really want to.
There are 'unsupported' versions of the firmware floating around on the forum that will work with your card. Ask here and someone might just send it to you.
You just did not hear it from me.....
