Gallderhen
Hi,
I got a new Linksys WAG120N adsl modem/router a few days ago, and all went well until I setup and used the wifi (i.o.w wired connections are fast and stable for 24 hours +)
I first tried using the automatic wifi setup with WPA2-mixed security mode (also tried WPA-Personal). Everything went well until I connected to the router using an android phone. The phone would connect but after anything from 2 to 20 minutes, the connection to the router would timeout intermittently and eventually all connections to the router would stop (including access to the web interface). But if I look at the router I can see the wired lights, wifi light and internet lights blinking (indicating traffic of some sort).
I then tried a possible fix (from the internet) to set the wireless to manual and the mode to G, but this also failed.
I hope someone might have had the same problem and gotten a proper fix for it?
-G-
-G-
