Linksys Wireless Router Model : WRT54GX
rpm
Admin
Staff member
Johannesburg
Posted by: lexor
Description: Standards: IEEE 802.3, IEEE 802.3u, IEEE 802.11g, IEEE 802.11b Channels: 11 Channels (US, Canada) 13 Channels ( Europe) Ports/Buttons Internet: One 10/100 RJ-45 Port LAN: Four 10/100 RJ-45 Switched Ports One Power Port One Reset Button Cabling Type UTP CAT 5 LEDs Power, DMZ, Wireless, Ethernet (1, 2, 3, 4), Internet RF Power Output 18 dBm for Wireless-B/17 dBm for Wireless-G UPnP able/cert Cert Security Features Stateful Packet Inspection (SPI) Firewall Wireless Security TKIP, AES, 802.1x, WEP, Wireless MAC FilterinThe Wireless-G Broadband Router with SRX is really three devices in one box. First, there's the Wireless Access Point, which lets you connect Wireless-G, Wireless-B, and other performance-enhanced SRX devices to the network. There's also a built-in 4-port full-duplex 10/100 Switch to connect your wired-Ethernet devices together. Finally, the Router function ties it all together and lets your whole network share a high-speed cable or DSL Internet connection. The Wireless-G Broadband Router with SRX combines smart antenna technology with standards-based Wireless-G (802.11g) networking. By overlaying the signals of two Wireless-G compatible radios, the "Multiple In, Multiple Out" (MIMO) technology effectively doubles the data rate. Unlike ordinary wireless networking technologies that are confused by signal reflections, MIMO actually uses these reflections to increase the range and reduce "dead spots" in the wireless coverage area. The robust signal travels farther, maintaining wireless connections up to 3 times farther than standard Wireless-G. And the farther away you are, the more advantage you get -- the higher data rate and reflection-friendly technology can yield up to 8 times more throughput than Wireless-G in some situations. The router avoids interference by dynamically switching to the clearest channel available. Even your standard Wireless-G and -B equipment will work better when communicating with SRX-enabled devices. To help protect your data and privacy, the Router can encode all wireless transmissions with industrial-strength WPA encryption. It can serve as your network's DHCP Server, has a powerful SPI firewall to protect your PCs against intruders and most known Internet attacks, and supports VPN pass-through. Configuration is a snap with the web browser-based configuration utility.
Price: R400.00
