Little Mod Rewrite help
Kloon
So I have this in my .htaccess
Code:
RewriteEngine On
RewriteBase /rewrite
RewriteRule ^(.*)$ user.php?id=$1 [L]
and I have a php file
PHP:
<?php
  echo "username is ".$_GET['id'];
so according to me if I visit http://127.0.0.1/rewrite/theusername the php file should return theusername, but instead it returns user.php
Got it working fix was
Code:
RewriteEngine On
RewriteRule ^(.*)/$ user.php?id=$1
forgot the /$
k finally got it working with the following code, this is what baffles me cause it exactly the same as the first try just a bit strick when it comes to what characters to use.
Code:
RewriteEngine On
RewriteRule ^([a-zA-Z0-9_-]+)$ user.php?id=$1
RewriteRule ^([a-zA-Z0-9_-]+)/$ user.php?id=$1
Yeah, you limit the REGEX there to only allow A - Z (upper and lower case), 0 - 9 a underscore and dash characters. Do you want it to accept all characters?
You could achieve a more lenient rewrite with:
Code:
RewriteEngine On
Still got a problem if I go to http://127.0.0.1/rewrite/test/ it works but if I go to http://127.0.0.1/rewrite/test it fails
The second URL failed because the rewritten template explicitly required a "/" after the URL. My recommendation above would cater for both.
Code:
RewriteEngine On
I only want to allow that chars, thing is in my first try I did use RewriteRule ^(.*)$ user.php?id=$1 and it dit not even pick up http://127.0.0.1/rewrite/user
Code:
RewriteEngine On
No the statements above does not work, it is supose to work acording to my regex knowledge but it doesn't
