Load-shedding heater
Sir Bob
Has anyone found a safe solution to warm a baby's room during load-shedding.
I am not keen on gas in a small room.
Also not keen on gas heater that I am not around or in the room often to monitor.
Uses a similar one for my daughters room.
I've been wondering about this same issue.
The best advice I've gotten is to insulate the room as much as possible to keep heat in, whether that be putting up thicker curtains, insulation in the roof, and rugs on the floor (if tiles/hardwood). Secondly, panel heaters are your most efficient and safest option.
Gas and paraffin heaters are apparently a big no-no because of the fumes released.
It won't work during LS though. Unless you want him to get inverter/generator/solar setup - now that will be a mybb suggestion. Bru - why don't you migrate to a country where there is no LS ? :cool:
Heat the room when there is electricity and keep it closed, then put them in a sleepsack with a blanket on it.
Cheapest and safest way is with an aircon. Roughly half the electricity consumption of other heaters.
The aircon below will provide 2640 W of heating and use 942W of electricity to do it
https://www.takealot.com/hisense-12...onditioner-with-heating-function/PLID60868843
How long an oil-filled radiator stays warm, it depends on the external temperature, it may stay warm from an hour and a half to two and a half hours. The main reason for stay warm is the diathermic oil that is used to evenly distribute the heat to the surroundings.
A rug under the cot should help. Thanks
The real problem will be nappy changes and bath time.
Hopefully bath time can be structured around load-shedding but nappy changes cant.
The more area you can cover with a rug, the better. Not a huge fan of carpets myself but if it helps, I'd be willing to try it.
The sad things we have to worry about living in SA, hey :cautious:
But OP asked for load-shedding friendly ... does yours not use electricity? :)
Don't worry about it.
You will get very good at nappy changing...:D, so you can do it very quickly.
And bath time, your geyser should stay hot enough for a baby's bath because they cannot have scalding water.
These are both short-term situations where you are around to monitor, so your worry about gas is moot?
Bathing maybe but will take gas time to warm up the room that the baby will be changed in.
Before load-shedding a small panel heater left on kept the room at an OK temp,
Your other worry about gas was that it was a small room. :unsure:
Blasting a 3-panel gas heater at the changing station for 10 mins will warm it up.
Anyway, don't worry, babies are fat for a reason.
ok maybe its a medium size room depends who you ask...
It might be the solution but not very comfortable for the baby to sit in the dirty nappy also not fun for a midnight nappy change to turn into a 15 minute event. Lets see how winter goes.....
Also need to google that maybe gas isn't an option for other reasons.
