Francisco2580
- Feb 20, 2023
Good afternoon.
With the current state of affairs relating to loadshedding, I have lost all patience with just powering through loadshedding. I want to acquire an affordable battery and inverter combo. I have checked takealot for ease of use and found the following:
Inverter: JRY Power Inverter 500w - R690.00
Battery: BT 120AH 12v Deep Cycle Acid Battery @2 - R5'998
The inverter is listed as providing >90% effiency (i still bargain at 80% to be safe), as well as being able to charge the battery. The inverter provides a car port charging cable. My thought is to just convert it to a house plug socket.
My power usage that I want to make provisions for is for 150w/200w usage. A sloadshedding is at stage 6 intervals of 4 hours, i want to be able to either watch tv (150w) for the 4 hours, or use my fans (2 @65w) for the 4hours. I calculate this usage as 150w x 4 = 600w / 12 v = 50ah. The batteries provide 2 x 120ah = 240 ah / 50% (not using more than 50%) = 120ah / 80% efficiency = 96ah.
My questions are as follows:
1. Will this be sufficient to use for my setup, or are there other component needed or factors to consider?
2. Will it be possible to convert the cable to a house socket adapter, or are there complication with that?
3. Is my calculation accurate regarding the power requirements?
4. Will the inverter be able to fully recharge the batteries in between the 4 hour invervals of no loadshedding, or do I need an additional battery chargers? If so what charger would be recommended?
