Cool thanks, I'll check out landmarkpc.
I don't have any recent pics online, this is from 2005 when I first set her up, before painting her black.
back in the day I used 15% antifreeze to prevent corrosion and algae.
But its an all copper rig, and algae grew after 6 months. Then I drained all the coolant, painted the radiator black, as well as all the external pipes, covered the inside of the window with black plastic to keep the light out, and its been running 4.5 years with no algae.
I also cut a little hole in the top for an 80mm fan that runs on 5v, it hardly turns, it just basically lets the heat buildup out.
Everything that generates significant heat is watercooled, but ofcourse all components in the PC generate heat. Adding the little fan on top dropped the internal temperature a good 15C (I'd guess) and you can't hear it, because it hardly turns. Its not nice having a fan in my fanless system, but yeah, its practical. I haven't even bothered to connect it properly, I just shove the wires into a molex connector, sometimes they fall out hehehe, then I'm like 'oh, the fan's not running' a few weeks later. Just having the hole there helps.
It wasn't a ground up build, it was a hack, conceptual evolution.
Its not the best silent system ever, it was my first build, I've got much better designs in mind, but lack of a decent garage/workshop/workspace and free time means its vaguely in the future.
The only
custom PC I've built since then is my low power server. Also sort of a hack.
When I get my hacking/building site up I'll put it all on there, construction pics etc.
It looks a lot more sealthy now. Just a silent black box where the air is kind of warm above it. People don't know what the **** it is
It was good to experience passive radiator. Next time I won't go 100% passive radiator, but I'll go 100% passive water flow.
