Looking for some help
Lee.86
Durban
Hi
I have a dell laptop, I had uninstalled some old software and am unsure of what triggered this or how to stop it. The laptop starts up as normal and works fine, however when I now try to install or uninstall, I get a popup that says, wait for another program to finish uninstalling. I've restarted and still get the same error, any ideas on what i can to to stop it? Thanks. :confused:
This forum really needs to be renamed from "Software and Web Development" to "Software Development and Web Development" :)
* Restore your system to the day before you performed the uninstall.
**Use the MS Fixit tool to remove the software you want to get rid off.
Report back here :)
Sounds like the Windows Installer service is corrupted
Hey guys..
Thanks for the advice Yuu, gave it a try... for some reason the system restore has only the current day saved to restore from. i tried the MS Fixit tool, that's a handy tool, but also no luck.
You're right Sonic2K, but instead of disabling the installer, I've chosen to wipe everything and start again.
Thanks for the help once again. ;)
