Losing Signal Periodically
Aokiji
this is with a new product the Rainone 5g package.
bundled router keeps losing signal but other sim cards keep the signal.
besides the fact there's only 1 tower here and no news if 5g will be coming anytime soon
also about 1.2km away from the tower can see it from my house
Have tested this in multiple areas inside my home to see if its not perhaps signal related why its dropping but it drops regardless of what area and signal quality
Not the best but its decent atleast
Stays offline for quite a while before getting signal again for a while and then dropping
I am not familiar with the software. My guess is that you can only use 5G? If that is the case I would recommend moving it around till you get a better signal. I get the best signal 2m from the ground. As stupid as this sounds it is the only thing that worked for me while I was using Rain. But honestly I couldn't maintain a stable signal. It is why I canceled with them.
signal is not the problem..
4G signal
RSSI = -67 dBmRSRP = -77 dBm
RSRQ = -11 dBSINR = 22 dB
current signal @ work still disconnects reboot does not work. power cycle sometimes solves the problem for a while only to disconnect again
4G signal
I suspect a faulty router. I had the same problem with my old Huawei router. Maybe go to someone else's home and test it there. If the problem is location then you should see different behaviour?
dont know what brand this router is suspect its zte checked the routers from huawei none looked like this one and the router interface is lack luster
Stayed connected for about 30 mins , dropped again
i hung my Rain router outsude on the burglar bars in the middle of a 4 m wide window ,signal dropout improved ,i then put a big birdcage over it signal got better it wasnt dropping anymore ,put a big bucket over the birdcage for rain ,someone took the bucket ,it rained ,modem burnt out ,cancelled rain ,never went back .
EDIT ..True story
if you fart on the tower can smell it that's how close I am to it, trust me signal is not the problem. however, staying connected without the need to power cycle is on a whole diff level.
tower is 5 houses away from me ,had the exact same problem.i was told im too close hence putting the box outside and higher up the signal radiates out at an angle according to what they told me .gave up eventually ,had to constantly restart the router ,that i set in the router software for every 30 minutes
have the same experience at house that`s 1.2km away
try it in your roof space if you have one ,or outside ,i found if i turned the router that it was sideon to the tower when outside it improved
My Telkom right now while listening to Music.
I don't know why Rain pushes so hard for 5G when 4G is more than able to provide good speeds.
problem is the router after some testing with support got a brand new dud xD , but anyway the replacement wil also not be delivered anytime soon as some smart ass when booking the replacement got my ID wrong ( they got it right the first time.. ) so cant schedule delivery and pickup. the rep on this forum has gone dark now .. maybe using same router as the one i got
my mtn normaly during the day its on ( no service ) more than anything else the loadshedding is also smashing this tower so its not winning sometime s off for 5 days on end not really reliable
at night do 100+ easily but as stated before only if it actually works xD
