LTE 35dbi antenna for B593-601
Perrie
4G LTE 35DBI SMA Antenna
Has anyone used this antenna on their B593 as opposed to a Poynting XPOL-0001 for example?
I am looking for an antenna that I can use on a window. I currently have LTE reception on Telkom but the B593 shows no signal bars. I cant complain about the connection, its 100% stable and getting 3G speeds (taking into account according to Telkom I am not even in a LTE zone).
Thanks!
It only supports LTE band 3 - 1800MHZ (Vodacom, MTN), see http://en.wikipedia.org/wiki/E-UTRA
All other bands are not used by SA networks, if you need switch to 3G - fail - 900MHz, 2100MHz bands not supported. It seems to be WiFi adopted antenna, it covers more WiFi bands than cellular. It is why I don't believe support for LTE band 3, it could be a lie.
