LTE problems - Really slow Smart Broadband LTE
Sokum
Hi Guys,
I am having trouble with my LTE connection at home, I've tried to point the antenna to both the closest towers and I just can't reach anything above 1mbps I'v done numerus speedtest changed the APN from TelkomSA to Telkominternet and vice versa to no aveil. This started at about 3 weeks ago.
This is from the router in question:
Device Information
Device name: B315s-936
IMEI: 866853028383896
IMSI : 655020003439210
My number: Unknown
Hardware version: WL1B310TM02
Software version: 21.313.03.00.372
Web UI version: 17.100.09.00.03
LAN MAC address: C4:F0:81:AB:24:88
WAN IP Address: 165.xxx.xxx.xxx
WAN IPv6 Address: Unknown
PCI: 362
CELL_ID: 4210178
RSRP: -91dBm
SINR: 5dB
Can someone please help.
Did you force your roiter to the 2300Mhz band? Remember that since Telkom has two bands sometimes the router prefer the slower band.
I'm on my phone so won't be able to link you right now but you should look for the thread toolbox for huawei hilink devices.
Use that tool to force it to 2300MHz which I'm sure would give you vetter performance.
Thanks Cavedog, and how difficult is it or can I easily brick the router?
Sorry for the late reply. Unlikely for you to brick your router. You simply need to edit 1 one with the toolbox and you are sorted.
Hi Guys,
Device Information
My number: Unknown
PCI: 362
CELL_ID: 4210178
RSRP: -91dBm
SINR: 5dB
Your SINR is terrible could be the cause of it i have a RSRP of -100 but a SINR of 19 Its not Uncapped LTE but works pretty much the same on SINR of 5 i am lucky to get 2MBps but with 19 get around 15-21MBps
