LTE Router connected via Mikrotik
darryn
Durban
Hi Guys
I have my LTE Router connected to a mikrotik which is doing dhcp i just got this today, i get an ip assigned to me fine on the LAN but i dont get one assigned to me at all via the WIFI
What am i missing here...
Thanks in advance
If I understand correctly the mikrotik is doing DHCP?
Is your wireless card added to the bridge interface and does the DHCP server run on the bridge interface?
Mikrotik isn't the easiest to use out of the box. If it has quickset it might help you to use that initially to learn but per above the bridged/switched parts affect how each interface speaks to the rest
Hi Guys
Thanks in advance
Just out of curiosity, why do you have a Mikrotik, is this for home use or are you building something?
Speed & efficiency for example, depends on your Internet connection. The standard issue Zyxel router with a fibre connection could only max 15Mbps. It was fine on MWEB fibre, but not nice if you pay to Cell C for 20+20Mbps unlimited. After replacing it with Ubiquity ER-X, speed upped to 21Mbps download and 18Mbps upload.
WUT
