Major Outlook Problem
Flanders
Hi, I'm hoping there's an expert out there who can help me with this.
I'm using Oulook Express 6 (the one from Office 2000) and I've run into a major problem. Yesterday my email started acting up. It would start to receive up to a certain point and then just stop with a general error (an unknown error has occured). It did this every time and bombed out at the same point although I can send mail with no problem. I logged on to webmail to see if there was a large email causing problems but it wasn't the case. I deleted the items on webmail and sent a test email to myself but the problem persists.
I searched a tech forum and found a thread explaining that if your inbox becomes too big you may experience this exact problem. I'm reluctant to archive because I often need to quick reference old emails so as an alterantive it said to copy your inbox to a new outlook folder called, say, 'old inbox' and then delete the messages in inbox. That, according to them, should fix it. I did this, being very careful to copy and not cut my inbox contents. While the contents were copying to the new folder, Outlook crashed.
When I opened Outlook again, my inbox was EMPTY and a large portion of the copied files in the new folder (the last year's worth of email) is gone. This is a big @#*%ing disaster for me. To top it off, my email still won't receive. Other people using the same mail server don't have problems so I'm sure it's a problem on my side.
One other very strange thing that has been happening is that since a few days ago, every time I clicked on a new/unread email, it would cause MS Office setup to start running as though I was running it off the CD!? I had to cancel it every time but if I let it run it would just tell me it's unable to locate the CD.
1. Is there a way to retrieve the mysteriously vanished inbox content?
2. Can anyone possibly tell me why Outlook isn't receiving?
3. What is up with this Office setup running when I click an unread email?!
Any help would be much appreciated.
Something has gone corrupted.
Hopefully your folders are still intact. do a search for inbox.mbx on your hard disk under /Documents And Settings/User/Local Settings/Application Data/Identities/{xxxx......xxxxx}/Microsoft/Outlook Express/ if there is a file there and it is big i.e. 500Megs+ then your mail is intact.
If you are unsure, PM me. I've done about 100+ recoveries and backups of this nature
Hi Turiko,
I have 2 large files called inbox in that location but they are .dbx and .bak. Both are the same size 2GB+ Will these help?
I have Office 2007 but haven't installed so if I back up the files in this Oulook Express folder and then install outlook 07 and replace, will it work?
Sorry, I'm really quite clueless here.
Don't have a clue. I haven't upgraded office in years so if it works, I leave it alone. Now it doesn't so I'm stuffed. :p
I will probably pop in to Rage and see what's potting if Barry can get me another "backstage pass". :)
I'm almost 100% positive it will import from outlook express, even if it doesn't you won't lose the emails in outlook express.
Been using Thunderbird for years on my PC at home, managing multiple email accounts, with no problems. Nice to have all the add-ons too.
Outlook Express 6 isn't part of Office. Outlook is.
Ok, so does this mean my outlook express files are not going to be compatible with Outlook '07?
The maximum size of an archive can be 2GB - u get no warning about this.
This is probably the cause.
Got no warning at all. Both files are 2097 megs.
Yea flanders, thats why i am saying load outlook 2007 because it will ask if you want to import from outlook express or you just go tell it to.
The 2 files are totally different meaning you won't lose any data.
Good idea
Do a search on microsoft.com for this error.
+1
This is most def the cause.
Thanks for the helpful stuff here, guys. I'm off to troubleshoot.
