Making Heirloom gear twink.
Boomrooker
Gone make myself hunter twink lvl 19 already got the heirloom shoulder and bow for hunter now i just need the 2 daggers.
For more attack power and agility only another 40 badges to go. And i got the PVP Heirloom trinket.
Think this hunters gone own lvl 19 bracket :).
Already got lvl 66 hunter but too late to twink him now.
There is problems with the enchants on those gear they stay level 1 all the way through to level 80. I'm saving up to buy my Pala the Plate set but I'm not 40 yet :p
Indeed,Boe lvl19 gear is fully enchantable upto its Ilvl restriction so Blue vs Heirloom the blue would win when enchanted ;)
You dont need to be lvl 40 it turns to mail at lvl 1.
I would like to see blue shoulders that beats heirloom at lvl 19?If you can show me that?
:confused:
Sorry but I'm pretty confused now. In regards to the shoulders, you get cloth, mail and plate shoulders. You are saying I can buy the mail shoulders and they will change into plate at level 40 ?
That doesn't make sense
Comparatively any heirloom items are only meant to equal general blues,there may not be lvl19 blue shoulders,don't know,don't care,twinks are for tards that like to spoil the game for the rest who try battlegrounds for the first time,but Heirlooms aren't BIS always just because they're heirlooms - and can't be enchanted with high-lvl enchants
Boom, just a question.
You WTFPWN on your DK as you say, why go and play around in the level 19 bracket ?
I am tired of the dk need to play something else anything else rely pugging hc as tank getting REALLY frustrating lately i just had bad luck.
Healer yesterday full epic raiding stuff on him lets me die 5 times on trash my friend got blues and 2 epics and keep me up.BORED atm
And i never tried twinking actually i hate twinks.
Or ill jsut lvl nother alt more relaxing.
Or ill get Boomrooker to 80 and play moonkin again always had fun as fatowl man and i heard they alot better than they were in tbc.
But what I mean is level 80 BG's + Arenas vs level 19 BG's + Arenas to me it's the same thing. Unless you get WTFPWNED and create a twink to feel OP again. (I know I've done it before :D)
Lately I level toons to get them to endgame, it's alot more satisfying than logging in to do BG's :p
I love my new Pala, I will be able to full 2 spots at any given time and be awesome at it (Healing+Tanking) Can't wait.
Honestly, low level bg's suck dog balls. And the amount of Alliance twink in low level BG's now are insane. This happened because the horde won all the BG's. Be prepaired to have your hunter twink ripped to shreds ;)
Well i owned on my hunter at lvl 19 as marksman way before WOTLK dont know how they are now.And he was not even a twink.
You have no idea ;)
But sure go ahead, I'll do PvP and Arena on my Lock inbetween raids and then level my Other toons for end game raiding :)
Twinking is fun. It gives you "that something to do" when you're bored or want to kill an hour or two. What makes it more fun is doing it in a guild. There's almost nothing more satisfying than to see the entire alliance side demoralized and gutted by you and your guildies.
On TH High Honers Club are currently the biggest lvl19's only. You guys should try it, well at east once, it grows on you.
:confused:
If you buy the Plate BoA shoulders and send them to a low level char they change to Mail.
Once you hit 40 and have the Plate Skill they become Plate.
Actually they're at least on a Par with equal level Blues.
For example I got the level 61 Axe in BF last night and compared it to my BoA Axe which was at 61.
The BoA Axe came out quite a bit better statswise but the moment I level it becomes even better.
Most of the items used by Twinks at that level are items around 17-18 iLevel so a level 19 BoA is actually quite likely to be better.
Meh, I have badges to spare, mebbe I should twink out some level 19. I have all the good low level enchants for those guys.
Except your lvl61 Axe from BF could get crusader enchanted or even mongoose,BoA - not somuch ;)
Crusader has no level limit. Mines had Crusader on it for quite some time and quite frankly even now you need to be cracked to pop Mongoose on an item while leveling.
At level 19 you can only put on the non-limited enchants anyway.
Can't put crusader on BoA - lvl1 item.
LVL19 items however can take pre-bc enchants upto ilvl35
*Edit - Twinks put highest lvl possible enchants on items. This is about Twinking,not lvling so yes they would love mongoose on their items
1. You need a level 35 Item to put on Mongoose so that rules out that enchant for a lvl 19 Twink.
2. Crusader has no level limit at all. Twinks have been using it for ages and I have it on my BoA Axe.
If you don't believe me then go look up the enchant. It does not mention a level requirement anywhere.
The first enchants to have Level limits were the BC enchants.
All the pre-BC enchants have no limit.
Your first sentence completely contradicts your second one.
