Manually switch on led on fan ?
Stevo1
Is there a way to manually switch on this fan's Led ?
Someone mentioned if you have no controller the light would be on permanent green but i cant get it to light up. See picture, i fed it 5 volts and then 12 volts but to no avail.
Is there some sort of trick to it ? Does the fan need to run first on its seperate 12 volt supply then i need to feed the lights 5 volts ?
Antec prizm 120.
White striped wire is usually negative so i should have had the polarity correct.
If you fed the LED 12v and it's a 5v you've more then likely popped the led.
Thanks but there should be a way to simply just switch it on
