Marantz RC1400 universal remote control
rpm
Admin
Staff member
Johannesburg
by: Dolby
Description: For more information please see http://us.marantz.com/Products/556.asp# * Easy-to-Read LCD Display with Adjustable Contrast * Backlighting Feature for LCD and Buttons * Simplified Programming, Naming & Control Functions * Separate Channel and Volume Up/Down Keys Located for Easy, Comfortable Access * Large Memory Capacity * Non-volatile Memory Assures Programmed Commands will not be Erased from Memory * Macro Capability * Programmable Timer function * Built-in Commands for Marantz A/V Components and Other Major Manufacturers Products I find the display a little too dim for my bad eye sight and haven't made use of this since I bought the Logitech Harmony. The remote comes standard with many of Marantz higher end AV receivers and is a perfect replacement or 2nd remote. Only issue is that one of the two manual backlighting buttons don't work - so I just use the other. No manual - but can be downloaded at http://us.marantz.com/Products/556.asp# PM me for more info
