Cloud
I ran into a bit of a problem with a project I am working on and wonder if anyone has any ideas.
I bought a 36 port USB hub that comes with a 5V 4A power supply. After plugging in 25 Huawei S7 tablets the poor power supply nearly melted (in fact, it did become soft in parts) and shut itself down after about 15 mins.
After doing some research I noticed that the max output for one USB port is supposed to be 500mA, which means the max the 36 port hub can charge is 8 (500mA x 8 gives 4A). This is a bit of a bummer, as I need to be able to charge 34 simultaneously
Common sense (and that's all it is, have no formal education in electronics) says I need to find a 5V 17A power supply to charge the hub as this should give each port at least the 500mA it needs.
But that is easier said than done, most hubs come with underpowered power supplies and I have yet to find a 5v supply with anything more than 4A.
Any ideas or suggestions?
