maths question regarding linear algebra
vanillathunder722
durban
Hello basically i have to determine whether equations form a linear system or not.
If you take a look at ths equations
4x - y + 2z = -1
-x + (ln2)y - 3z = 0
i would like to know what the (ln2) stand for?
4x - y + 2z = -1
To only time the equations are nonlinear is when the variables are non linear. So, if my math is correct, both are linear
The ln(2) is a log with e as the base instead of 10. You can type in ln(2) on most sci calculators and get an answer. There that is not a variable and does not contribute to determine if the equation is linear or not
If it was ln(x), it would've been nonlinear
Ps. I haven't touched advance maths in years, so take it the advise with caveats
yes it is a linear system end of story
if you spot x^2, x^3...x^n
2^x or ln(x) or sin(x) etc its not linear
