Medion X6815 battery
Johnatan56
Vienna
Hi,
does anyone know where I can get a battery for a Medion X6815 and if possible a universal charger that would work with it?
My friend's charger broke and messed up the battery, he got a quick fix but needs to replace the battery as well (it doesn't hold a charge).
On amazon I found this: http://www.amazon.co.uk/Medion-Erazer-MD97971-Battery-4400mAh/dp/B00CJVLP3Y but it isn't in stock anymore.
(as an aside, what do you think his laptop would be worth if he replaced the battery/got a universal charger, laptop specs: http://www.notebookcheck.net/Medion-Erazer-X6815.60465.0.html)
