Mercedes maintenance plan
Saba'a
Interested in a 2nd hand mercedes c200.
However not sure if extending maintenace plan at cost of R155 000 for 2 years and extra 60 000kms worth it?
How much is a major service and specifically brakes?
It would probably be cheaper to pay for the services cash and cost a lot less than R 155k.
With some youtube and getting ferodo pads from Autozone, you could likely change the pads yourself. Brakepads are an easy change.
Unless the car has SBC, then it's a little more complex.
How much do you drive? How often do you service? But at 155k would say no.
What the ****? You can buy another car after 2 years with that money boet.
That sounds more than a little crazy.
Remember though, it is a maintenance plan extension so includes more than just services.
Yep but its really only brakes or my thinking goes
Still not realistic at all. The car will not be worth much more than that.
For context it costs 50k to renew the plan on a Porsche cayenne for a year.
What are the KMs? Sounds like the price to extend to 180000km.
