Mesh wifi
Bruceg
hi, I am uusing 5 airties 4920 in my house, is there any other mesh system better than the airties?
Hi Bruce - what specific additional functionality are you looking for? Additional range? Faster speeds? etc? that way we can support with better recommendations
Hi, running 5 airties in a daisy chain from the router across the house, end of the chain has lost over half of the speed. Was thinking of moving the router to the middle of the chain and let the signal spread 2 ways instead of one long length
Are they connected via cable or over the Wifi? If you can move the main node to the centre then try that and then also try running cable
