renier8
- May 13, 2009
Hello.
On my PC, my microphone is extremely soft. Even in the test, SIRI (or whoever) says they could not hear me clearly. However, the speakers work fine.
I have read up on this, and I have found and adjusted every possible sound setting, including updated drivers. It still does not help. The mic works fine on my Laptop, though.
Is the mic hardware (In) on the sound card a separate entity from the speaker (out). I mean to ask, that if the speakers work fine, and mic does not, can it be that the sound card is faulty?
Appreciate any input
Thank you.
Renier
Thank you.
Renier
