Microsoft Edge browser to block Flash ads
I never use; see the need for using Edge on my Win 10 lappie hey...
It's getting better and better. Changelog of latest insider build:
Edge
Edge has been updated from version 34.14295 to version 37.14316 with the following updates
You can now upload folders
On Mobile, when an app opens a new tab, pressing back will now close it
On Mobile, when typing in a text box, you can now use the pase button above the keyboard
Edge now supports importing favorites from Firefox
Imported favorites will now be put in their own folder, instead of the already existing favorites folder
The Favorites hub now uses a tree view
When closing Edge with running downloads, Edge will now warn you
You can now set a default save location for downloads
Edges default opening settings are now a dropdown
There is now an accessibility tree view in F12
You can now debug extensions through F12
You can now use DOM API profiling
EdgeHTML has been updated from version 14.14295 to version 14.14316 with the following updates
Default parameters
Async/await
Object.values and Object.entries
Opus audio format
Time element
Date element
Output element
Color input type
Canvas Path2D objects
Web Speech API
The User Agent String has been updated
The following flags have been added
ES6 Regex symbols
Fetch API
Web Notifications API
http://changewindows.org/build.php?id=126
Good move, but I keep Flash disabled. I am not sure I will be able do it on Edge.
