Midstream Estate's plan to avoid stage 4 load-shedding
Jan
Who's the Boss?
Staff member
The Rabbit Hole
How one top Gauteng estate will avoid stage 4 load-shedding
The sought-after Midstream residential estate in Gauteng has revealed how its Smart Grid Energy Plan will protect residents from load-shedding up to stage 4.
As reported by Daily Investor, Midstream first discussed the R200-million plan with residents at a special Energy Indaba on 7 February 2023.
Nice, especially if you live there or were looking to live there
Sounds good to me. Wishing them a speedy and successful implementation.
This new "federalized" community way of living in this sh**hole is the only way forward. Always nice to see people take action instead of moaning all day.
I fear though that many are going to be left behind. Attending one of the AGM meetings in our complex for instance is enough to spiral oneself into depression ... I can only hope the average complex/community have higher IQ's than the one I'm trapped in.
Someone literally suggested we get Tesla Solar Roofs installed the other day.
One other genius wants a centralized generator in a place with 60 units where just getting everyone to pay levies is a constant battle.
Yup.. the average at school, population etc means half the people are below average ;)
The main focus will be installing a large 8MVA battery bank that can store excess electricity generated by private solar farms, residential rooftop solar, Eskom’s grid, and, if necessary, Midstream’s fuel-based generators.
What kind of unit is MVA?
What is 8MVA in kW and kWh so that regular myBB people can understand.
It means the battery can deliver 8M Volt-Amps. It's a weird unit for a DC source, but essentially it means you can instantaneously pull 8MW out of it. For how long? They didn't say.
So VA is just another way of saying Watts.
So 8MW... 8 Mega Watts ... likely 8 Million Watt Hours...so 8000 households can pull 1000 Watts for 8 Hours.
If that's the case it's a crapton of storage.
No man. 8MW is a rate not capacity. 8MW is the flow rate through the bottleneck. We have no idea how much water (liters/MWh) is in the bottle.
For all we know it’s 8MWh, 10MWh or more…or less…who knows.
If it’s 8MWh then we can pull a rate of 8MW for exactly 1 hour. Because 8MW*1h = 8MWh
Who can clarify?
Who can clarify?
Do your own research.
Here's an example of a 2.8MVA battery bank, so it'll likely be a few of these stringed together:
You owe me biltong.
I suggest they spend this money on securing backup water-supply.
The dry years are coming.
You owe me biltong.
You write 2.8 MVA (MW)….that’s the rate i.e power.
But you highlight the energy capacity: 2.7MWh <— the ‘h’ tells you its energy.
This means that this battery going full blast at 2.8 MW will go from 100% to 0% in less than an hour as the capacity is less than its rate of 2.8kWh…it’s 2.7kWh.
The power is not its energy capacity.
Im thinking you should get the biltong ;)
