The filter is what you gave me
both are posted below
I noticed if I print, it only shows up to rule #7, not any further?
/ip firewall filter
add action=add-src-to-address-list address-list=Syn_Flooder address-list-timeout=30m chain=input comment="Add Syn Flood IP to the list" connection-limit=30,32 protocol=\
tcp tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner address-list-timeout=1w chain=input comment="Port Scanner Detect" protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=ICMP protocol=icmp
add action=drop chain=input comment=\
"Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT_ADDRESS LIST" disabled=yes dst-port=8291 \
protocol=tcp src-address-list=!support
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input dst-port=53 protocol=udp
add action=accept chain=input protocol=udp src-port=53
add action=accept chain=input comment="Accept to related connections" connection-state=related
add action=accept chain=input comment="Full access to SUPPORT address list" src-address-list=support
add action=drop chain=input comment="Drop all packets which does not have unicast source IP address" src-address-type=!unicast
add action=drop chain=input comment="Drop all packets which are not destined to routes IP address" dst-address-type=!local
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP protocol=icmp
add action=accept chain=output dst-port=4949 out-interface=ether8 protocol=tcp
add action=accept chain=output protocol=tcp src-port=3389
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=bogons
add action=jump chain=forward comment="Jump for icmp forward flow" jump-target=ICMP protocol=icmp
add action=add-src-to-address-list address-list=spammers address-list-timeout=3h chain=forward comment="Add Spammers to the list for 3 hours" connection-limit=30,32 \
dst-port=25,587 limit=30/1m,5
acket protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 protocol=tcp src-address-list=spammers
add action=accept chain=forward comment="Allow Twitter" layer7-protocol=Twitter protocol=tcp src-address=192.168.2.65
add action=accept chain=forward comment="Allow Facebook" dst-port=443 layer7-protocol=Facebook protocol=tcp src-address=192.168.2.65
add action=accept chain=forward comment="Allow youtube" layer7-protocol=Youtube protocol=udp src-address=192.168.2.65
add action=accept chain=forward comment="Allow Facebook" layer7-protocol=Facebook protocol=tcp src-address=192.168.2.68
add action=accept chain=forward comment="Allow Facebook" layer7-protocol=Facebook protocol=tcp src-address=192.168.2.89
add action=accept chain=forward comment="Allow Facebook" layer7-protocol=Facebook protocol=tcp src-address=192.168.2.15
add action=accept chain=forward comment="Block youtube" layer7-protocol=Youtube protocol=udp src-address=192.168.2.68
add action=accept chain=forward comment="Block youtube" layer7-protocol=Youtube protocol=tcp src-address=192.168.2.65
add action=drop chain=forward comment="Block VW" disabled=yes layer7-protocol=VWClub protocol=tcp src-address=192.168.2.0/24
add action=drop chain=forward comment="Block Facebook" layer7-protocol=Facebook protocol=tcp src-address=192.168.2.0/24
add action=drop chain=forward comment="Block youtube" layer7-protocol=Youtube protocol=tcp src-address=192.168.2.0/24
add action=drop chain=forward comment="Block youtube" layer7-protocol=Youtube protocol=udp src-address=192.168.2.0/24
add action=drop chain=forward comment="Block Twitter" layer7-protocol=Twitter protocol=tcp src-address=192.168.2.0/24
add action=drop chain=forward comment="Block Twitter" layer7-protocol=Twitter protocol=tcp src-address=192.168.1.0/24
add action=drop chain=forward comment="Block Facebook" layer7-protocol=Facebook protocol=tcp src-address=192.168.1.0/24
add action=drop chain=forward disabled=yes
add action=accept chain=ICMP comment="Echo request - Avoiding Ping Flood" icmp-options=8:0 limit=1,5
acket protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=return chain=ICMP
/ip firewall nat
add action=redirect chain=dstnat disabled=yes dst-port=443 protocol=tcp to-ports=8080
add action=masquerade chain=srcnat
add action=dst-nat chain=dstnat dst-address=196.15.170.130 dst-port=4949 protocol=tcp to-addresses=196.15.170.130 to-ports=4949
add action=redirect chain=dstnat disabled=yes dst-port=80 protocol=tcp to-ports=8080
add action=dst-nat chain=dstnat dst-address=154.117.185.86 dst-port=8080 protocol=tcp to-addresses=192.168.2.96 to-ports=8080
add action=dst-nat chain=dstnat dst-address=41.0.237.170 dst-port=8080 protocol=tcp to-addresses=192.168.2.96 to-ports=8080
add action=dst-nat chain=dstnat dst-address=154.117.185.86 dst-port=23 protocol=tcp to-addresses=192.168.2.96 to-ports=23
add action=dst-nat chain=dstnat dst-address=41.0.237.170 dst-port=23 protocol=tcp to-addresses=192.168.2.96 to-ports=23
add action=dst-nat chain=dstnat dst-address=154.117.185.86 dst-port=3389 protocol=tcp to-addresses=192.168.2.4 to-ports=3389
add action=dst-nat chain=dstnat dst-address=41.0.237.170 dst-port=3389 protocol=tcp to-addresses=192.168.2.4 to-ports=3389
add action=dst-nat chain=dstnat dst-address=154.117.185.86 dst-port=3390 protocol=tcp to-addresses=192.168.2.7 to-ports=3389
add action=dst-nat chain=dstnat dst-address=41.0.237.170 dst-port=3390 protocol=tcp to-addresses=192.168.2.7 to-ports=3389
add action=dst-nat chain=dstnat dst-address=154.66.208.246 dst-port=3390 protocol=tcp to-addresses=192.168.2.7 to-ports=3389
add action=dst-nat chain=dstnat dst-address=41.0.237.170 dst-port=37777-37778 protocol=tcp to-addresses=192.168.2.109 to-ports=37777-37778
