Mikrotik ML-PPP help
kwaggawerner
Somewhere in the east of South Africa
Hey Guys,
I'm in the process of beefing up a client's home internet, he wants 2 4MBit ADSL lines (hopefully soon to be 8 or 10Mbit each), I'm thinking two ADSL modems, with a Mikrotik board doing ML-PPP to the two gateways, the online manual specifies client-based policies, but how can I just do a straight-forward bond, with no policies? Are there any easier or more cost effective ways of doing this? Any tips would be appreciated, since my Mikrotik-experience is limited.
Hey Guys,
My understanding is that ML-PPP requires support on the server end. i.e. without operating a PPPoE server yourself that is set up to allow PPP-MP, you are probably out of luck.
That said, it may actually be the case that Telkom's PPPoE will do PPP-MP anyway, which I would be interested to find out.
You can't, you need ml-ppp on the esr side as well.
Out of curiousity, has anyone ever tested whether the Telkom PPP servers have PPP-MP enabled, or not? Should be easy enough to do with two Telkom accounts, even over the same ADSL line, if you know how to set it up on your side.
