MiTv stick problems .
RSA1977
Hi everyone ,so I have been using 1 stick for the last 2,5 years . Recently was given another Tv so I purchased another stick to use on the 2nd Tv . I am unable to use either of the sticks on any Tv except the original . I have tried to see if it works even by placing another Tv in the same room as the original . If the original TV has a stick the second Tv and stick works only for 3 minutes approximately and then stops working . We have uncapped fiber from Afihost .
We are also using a TP link to ensure full wifi coverage in the whole house . Also ever since loading the second stick onto the original TV Netflix is so slow to the point its unwatchable . You tube and the other apps work as per normal My brother runs 3 sticks on 3 Tvs ,what am i missing ?
  • Wow
Reactions: Yuu
Have not reached that point on the second stick just checking if youtube would work as a test. Only signed in on original stick
did you buy the 2nd stick new or 2nd hand?
Can you access the menu of the firestick to even get to Youtube without linking a google account etc?
Have you tried a factory format and start fresh?
So i did the factory reset /hard reset and still nothing . Tried it with another tv at work it works fine ,even the original one at home the second stick works no problem . Still not on any other tv at home besides the original . My brother will take it home and test to see if its a network problem ...
So the stick works with no problems at my brothers place ,network or router ?
