Monitor arm
I'd like to buy a dual monitor arm for 2 24 inch monitors. It should be of the type that clamp to the edge of the desk.
Problem is that I'm worried about the stability and build quality. It is not easy to gauge online. I have a budget of about R2500
Can anyone recommend something from personal experience?
I bought a single arm North Bayou. it was under R500. quality is not bad for the price. It gives the option to mount on edge or drill a 10mm hole in the desk. They do sell dual also, but I think 2 single arms will give you much more reach.
That one?
@Master Blaster
https://www.takealot.com/nb-north-bayou-dual-arm-adjustable-monitor-desk-mount-stand/PLID54553925
That one?
@Master Blaster https://www.takealot.com/nb-north-bayou-dual-arm-adjustable-monitor-desk-mount-stand/PLID54553925
