DotKomrade
- Feb 24, 2009
I'm curious whether anyone uses screen calibration and if so what system? The reason I ask is that I recently did some processing for someone using the default colour profile on my macbook pro, and the images all looked pretty *** on her older macbook pro.
I then started messing around with the different profiles, but it's hard to tell what is actually right. For instance, the sRGB profiles look much cooler than the default. I got hold of a program called SuperCal which seemed like it did a pretty good job, but now I'm thinking of investing in a spyder system.
I'm bothered because I've never really looked into it and now I'm worried about all the other stuff I've designed or processed that probably looks totally wrong on other systems...
