Which make and model of monitor..?Hi all
Where can I find/buy a monitor arm/bracket for a non vesa monitor?My monitor doesn’t have the vesa mount at the back
Which make and model of monitor..?[/QUOTI have a Dell SE2717H
You have the option that Lupus suggested, or this if you want something that's integrated:
HumanCentric VESA Mount Adapter for Dell SE2416HX, SE2717HX, SE2717H, S2216M, SE2716H, SE2216H, S2817Q, SE2417HG, S2316M, S2316H, SE2416H and More [Patented] https://www.amazon.com/dp/B01DAYR3ZM/ref=cm_sw_r_cp_apa_i_xR4SCb69FDZK1
Check this out on takealot, http://takealot.com/og/v1/PLID42176641
This mounts in place of the stand if your monitor.. take if the stand and put this adapter on in place of it..This looks great thank you. So this would basically mount onto the X part of the mount if I’m correct?Have you bought from amazon before? What are there services like
