MSI Geforce 8600GT 512mb 128bit
rpm
Admin
Staff member
Johannesburg
Posted by: HlTMAN
Description: The card is like new.I have the box CD drivers of it.Asking price is R900.I get good graphics out of it and I can play sertain games on high graphics.I can paly doom3 on high graphics getting 50fps and i got a single core amd 3200 and 1gig ddr400 ram.So the card is wmuch more worth R900.Here is it's specs:GeForce 8600GT Chipset Features HDMI with Audio Integration Solution (Optional) The NVIDIA® GeForce® 8 Series graphics card supports HDMI with audio integration solution. With a DVI-to-HDMI adapter and an extra signal cord through the bracket, audio source from sound card(S/PDIF) can be integrated into HDMI interface by simply plugging the cord into the pinhead located on graphics card. Only 1 single HDMI cable is required while streaming audio/video data to flat-panel display devices, such as Plasma/LCD TVs, or projector. NVIDIA CineFX 5.0 Shading Architecture • Microsoft Vista Features• Vertex shaders- Support for Microsoft DirectX 10.0 Vertex Shader 4.0- Encompass' Transform and Lighting- Displacement mapping- Geometry instancing• Pixel shades- Support for DirectX 10.0 Pixel Shader 4.0- Support for full pixel branching- Support for Multiple Render Targets (MRTs)- Infinite-length pixel programs• Next-generation texture engine• Full 128-bit studio-quality floating point precision through the entire rendering pipeline,with native hardware support for 32 bpp,64 bpp,and 128 bpp rendering modes. NVIDIA SLI Technology • Patented hardware and software technology allows two GPUs to run in parallel to scale performance• Scales performance on over 60 top PC games and applications• Support for NVIDIA nView multi-display for scalable performance across two displays. API Support • Complete DirectX support,including the latest version of Microsoft DirectX 10.0 Shader Model 3.0• Full OpenGL support,including OpenGL 2.0 NVIDIA Digital Vibrance Control (DVC) 3.0 Technology • DVC color controls• DVC image sharpening controls NVIDIA UltraShadow II Technology • Designed to enhance the performance of shadow-intensive games,like id Software's Doom 3 NVIDIA Intellisample 4.0 Technology • Advanced 16X anisotropic filtering (up to 128 taps)• Rotated-grid antialiasing for removing jagged edges for incredible edge quality• Support for advanced lossless compression algorithms for color, texture,and z-data at higher resolutions and frame retes• Fast z-clear• Support for normal map compression• New transparent supersampling and transparent multisampling antialiasing modes. NVIDIA PureVideo Technology • Patented hardware and software technology allows two GPUs to run in parallel to scale performance• Three dedicated video engines• MPEG-2 HD and WMV HD video playback up to 1920 X1080p resolution• H 264 hardware decode acceleration• Decryption supported for all standard HD Video formats-AES-128 CTR mode,AES-128 CBC mode,and AES-128 ECB mode.• Industry's most advanced video algorithms• Overlay color temperature correction• Microsoft Video Mixing Renderer (VMR) support for multiple video windows with full video quality and features in each window• Integrated HDTV output. 64-Bit Texture Filtering and Blending • Full floating point is supported throughout entire pipeline• Floating point filtering improves the quality of images in motion• Floating point texturing drivers new levels of clarity and image detail• Floating point frame buffer blending gives detail to special effects like motion blur and explosions Preformances • Graphics Bus Technology: PCI Express DDR2• Core Clock (MHz): 540• Shader Clock ( MHz): 1188• Memory Clock (MHz): 800• Memory Amount: 512MB• Memory Interface: 128-bit• Memory Bandwidth (GB/sec): 22.4• Fill Rate (Billion pixels/sec): 8.64• RAMDACs (MHz): 400
