Hi ginggs
Thanks once again
these are the readings I found for both modems, not sure if that is what you want
I think it is.
Regarding installing the Windows application, I tend to agree as the first time I installed
the first modem I never did anything it just worked after i had created a connection.
I am writing this off my wife's lappy with the new modem and the signal is 3G..HSPA
but constantly fluctuating from 2G..UMTS and often disconnecting, which is a pain in the
backside but it is much better than the old modem, not if complaining to my local MTN shop
will make a difference (maybe it's time to think about ADSL) I'd like your advice on that too.
Thanks again & Regards
Old Modem
After the last time stamp
[ 310.096246] usb 1-4.1: new high-speed USB device number 6 using ehci-pci
[ 310.199367] usb 1-4.1: New USB device found, idVendor=12d1, idProduct=1003
[ 310.199372] usb 1-4.1: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 310.199374] usb 1-4.1: Product: HUAWEI Mobile
[ 310.199376] usb 1-4.1: Manufacturer: HUAWEI Technology
[ 310.358854] usb-storage 1-4.1:1.0: USB Mass Storage device detected
[ 310.359395] scsi4 : usb-storage 1-4.1:1.0
[ 310.359864] usbcore: registered new interface driver usb-storage
[ 310.368790] usbcore: registered new interface driver uas
[ 310.430626] usb 1-4.1: USB disconnect, device number 6
[ 311.451708] init: usb-modeswitch-upstart main process (2120) terminated with status 1
[ 317.720237] usb 1-4.1: new high-speed USB device number 7 using ehci-pci
[ 317.823233] usb 1-4.1: New USB device found, idVendor=12d1, idProduct=1003
[ 317.823237] usb 1-4.1: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 317.823239] usb 1-4.1: Product: HUAWEI Mobile
[ 317.823241] usb 1-4.1: Manufacturer: HUAWEI Technology
[ 317.827921] usb-storage 1-4.1:1.0: USB Mass Storage device detected
[ 317.828126] usb-storage 1-4.1:1.1: USB Mass Storage device detected
[ 317.828279] usb-storage 1-4.1:1.2: USB Mass Storage device detected
[ 317.828872] scsi7 : usb-storage 1-4.1:1.2
[ 317.829031] usb-storage 1-4.1:1.3: USB Mass Storage device detected
[ 317.829873] scsi8 : usb-storage 1-4.1:1.3
[ 317.860747] init: usb-modeswitch-upstart main process (2162) terminated with status 1
[ 317.875903] usbcore: registered new interface driver usbserial
[ 317.875928] usbcore: registered new interface driver usbserial_generic
[ 317.875942] usbserial: USB Serial support registered for generic
[ 317.898771] usbcore: registered new interface driver option
[ 317.898792] usbserial: USB Serial support registered for GSM modem (1-port)
[ 317.898915] option 1-4.1:1.0: GSM modem (1-port) converter detected
[ 317.899622] usb 1-4.1: GSM modem (1-port) converter now attached to ttyUSB0
[ 317.899682] option 1-4.1:1.1: GSM modem (1-port) converter detected
[ 317.900040] usb 1-4.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 318.833545] scsi 7:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 318.836895] scsi 8:0:0:0: Direct-Access HUAWEI MMC Storage 2.31 PQ: 0 ANSI: 2
[ 318.846397] sr1: scsi-1 drive
[ 318.846572] sr 7:0:0:0: Attached scsi CD-ROM sr1
[ 318.846651] sr 7:0:0:0: Attached scsi generic sg2 type 5
[ 318.846903] sd 8:0:0:0: Attached scsi generic sg3 type 0
[ 318.856537] sd 8:0:0:0: [sdb] Attached SCSI removable disk.
New Modem
After the last timestamp
[ 212.508271] usb 1-4.2: new high-speed USB device number 6 using ehci-pci
[ 212.601015] usb 1-4.2: New USB device found, idVendor=1bbb, idProduct=022c
[ 212.601018] usb 1-4.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 212.601021] usb 1-4.2: Product: HSPA+ USB Modem
[ 212.601023] usb 1-4.2: Manufacturer: SCD
[ 212.646262] usb-storage 1-4.2:1.0: USB Mass Storage device detected
[ 212.646343] scsi4 : usb-storage 1-4.2:1.0
[ 212.646445] usbcore: registered new interface driver usb-storage
[ 212.657580] usbcore: registered new interface driver uas
[ 213.645579] scsi 4:0:0:0: CD-ROM USBModem Mass Storage 2.31 PQ: 0 ANSI: 2
[ 213.654932] sr1: scsi-1 drive
[ 213.655124] sr 4:0:0:0: Attached scsi CD-ROM sr1
[ 213.655224] sr 4:0:0:0: Attached scsi generic sg2 type 5
[ 214.015587] ISO 9660 Extensions: Microsoft Joliet Level 1
[ 214.039474] ISO 9660 Extensions: IEEE_P1282
