MTN usb modem connection problems
I think thats what you mean
roy@roy-desktop ~/scripts $ ls -l
total 4
-rwxr-xr-x 1 roy roy 131 Dec 29 15:51 usbmodem.sh
ok
sorry it taking so long, I am working on a laptop and having to transfer data from one pc to another
total 4
No Problem, but I'm actually looking for the contents of the file, so within the scripts folder again run this command
cat usbmodem.sh
Then post the output please.
Ah??
I enter that command in the ubmodem.sh file
I'm not sure where you mean
No, that is an external commend, not part of the file the only thing in that file must be
Code:
anton@anton-mint:~/scripts$ cat usbmodem.sh
#!/bin/bash
sudo modprobe -v option
sudo echo "1bbb 022c ff" > /sys/bus/usb-serial/drivers/option1/new_id
It must look like this file
Anyways will take this further as it's going home time. Will see if I can help further from home.
roy@roy-desktop ~/scripts $ cat usbmodem.sh
#!/bin/bash
chmod +x usbmodem.sh
cat usbmodem.sh
ok thanks
if you would prefer to carry on tomorrow thats fine
#!/bin/bash
cat usbmodem.sh
Remove those last 2 lines. You only need the first three lines. See my previous post on what in the file must be.
hi again
#!/bin/bash
your offer to assist from home has made me feel very guilty & if you don't mind I think tomorrow would be better, you family is more important
cheers till tomorrow
Hi again
To recap: I opened Home/scripts/usbmodem.sh and removed the commands you
requested and ran the command 'cat usbmodem.sh' as you can see.
If this is correct do I have to re-instate those 2 commands back in to the original
file where I removed them from.
Hi again
That's perfect all you need are just those three lines. Those other are just commands to see if the file is correct.
So test that the script is working plugin the usb modem, open terminal, go to the scripts directory and the type this
./usbmodem.sh
Note the .(dot) in front of the /
It should just run and not give an error, then test to see if you can connect to the internet.
roy@roy-desktop ~ $ cd scripts
roy@roy-desktop ~/scripts $ ./usbmodem.sh
[sudo] password for roy:
./usbmodem.sh: line 4: /sys/bus/usb-serial/drivers/option1/new_id: Permission denied
I just get Network Settings & Network Connections but it doesn't open any further to
display the option to connect to MTN
Ok, is it possible to get teamviewer up and running? Reboot you laptop and then go the long way and connect your usb modem?
Hi
My laptop is my windows pc, my desktop is my linux pc, I am currently getting a very poor signal with my old modem
but connected just now and writing this on my desktop with linux.
I dont know any about teamviewer
ok done that, do I leave the other entry there.
I am having to run on the laptop again due to bad signal
