Hi DWPTA
Happy New Year and hope it's a good one.
Positive developments here, I will give you a brief run down.
After spending half the night thinking about it I decided to remove everything connected to
the desktop, clean it and set up about ½ metre away, the same place where the laptop works.
Left everything off except keyboard, mouse & screen, connected the modem direct to the pc…….BINGO!!!!!!
It would appear that the usb hub is faulty and there is a signal problem when my desktop is in it's
original position as when I tried the modem in the pc at first it was in it's original position and it
made no difference, I cannot understand that as it's been there for about 5 years trouble free, so maybe I also have intermittent faults on the ports too.
I will leave it out for now and monitor it and try various set ups.
I can get WCDMA (3G only) and Automatic (2G or lower) successfully though if I need to change it for any reason I have to do it on the Windows machine, but no issue really!
#Edit….additional issues are with my Network.
3g but constantly dropping signal (flashing red) searching network, then (flashing blue) for ages
before connecting, sometimes no connection for hours and when there is it's never more than one bar…….weird because I can connect with my laptop also with only one bar but stable???
Need someone to check this tower, the signal is very unstable or I must consider another package
with another provider. I will try to get them out first
In order to connect I used the original settings as before:-
roy@roy-desktop ~ $ su (enter)
Password: …………….
roy-desktop roy # modprobe -v option (enter)
insmod /lib/modules/3.16.0-41-generic/kernel/drivers/usb/serial/usbserial.ko
insmod /lib/modules/3.16.0-41-generic/kernel/drivers/usb/serial/usb_wwan.ko
insmod /lib/modules/3.16.0-41-generic/kernel/drivers/usb/serial/option.ko
roy-desktop roy # echo "1bbb 022c ff" > /sys/bus/usb-serial/drivers/option1/new_id (enter)
roy-desktop roy #
and also
~/scripts $ ./usbmodem.sh
Password:…………….
And that works too.
I have to enter whichever code each time I reboot, is there a permanent solution to avoid that
I didn't do anything else for fear of making a mistake and I need to just confirm with you again.
Also now when I check with the Modem Manager GUI I get an error when I try to request
*141# the error says:-
Error sending USSD
GDBus.Error
rg.freedesktop.ModemManager1.Error.Core.Cancelled: USSD
terminated by network
Hope you don't mind assisting but after all the issues prior I will understand if you wish to opt out.
I need to thank MyBroadband, Ginggs & yourself for your persistence and willingness to assist to a
sucessful conclusion, I could not have done this without you guys.
I have learnt quite a lot and I hope with all the hits others have too.
Once again thanks
Snowy
