N Nees Well-Known Member Joined Oct 21, 2016 Messages 138 Reaction score 4 Dec 8, 2019 #1 Hi guys, My TV box is stuck on the logo, did several resets and nothing, stuck on the blue light, any idea's what could be the problem? Thank you Attachments 15758125557843144038776771259136.jpg 2.3 MB · Views: 15
I insect Well-Known Member Joined Apr 11, 2008 Messages 300 Reaction score 155 Dec 8, 2019 #2 How to hard reset the TV Box MXQ Pro 4k? Disconnect the device from the power supply. Inside the AV slot insert a match or a thin stick until you find a small button, hold that button for a few seconds and connect the power supply. ... You will have a menu on the screen. ... Select delete all user data and press Tab.
N Nees Well-Known Member Joined Oct 21, 2016 Messages 138 Reaction score 4 Dec 8, 2019 #3 I did that quite a few times and still the same.
