My 10mb ADSL line synch speed keeps dropping ...
adamr
Fourways, Johannesburg
so i have been living fine on a 10meg line
Generally my router stats on the down link looked like
SNR - 8-9db
ATTN - 35db
rate - 11500kbps
Since yesterday
SNR - 11.5db
ATTN - 35db
rate - 9200kbps
been like this the entire day no matter what settings i tried
then this morn
SNR - 15db
ATTN - 35db
rate - 7200kbps
and again no matter what i try it just keeps this synch. The synch does not drop, SNR is stable. Why have i been "downgraded" when my line stats seem perfectly fine
i is not very happy atm ...
what does speedtest says about dl speed?
It's bad... Like 5mbps... Fault was logged and I've gotten a sms reply to say its fixed. When I get home will verify if it had been fixed
Yeah just remote tested this line and it's still synching at 7mpbs... But this time my snr has dropped from 15 db to like 9db. The attn has dropped from 35db to like 20db
So relogged a fault
So relogged a fault
Whats your fault reference? I'll check for you.
Thanks for the offer. It has been sorted. The issue was my profile showing incorrectly on one system and then correctly on another. But all good now. So assia was not turned on apparently
I have been struggling with this for ages, my max attainable rain is 10mb i am on a 10mb but my current rate is 7mb and no matter how many times i have asked them to reset service and or/ports it doesnt fix it.
What exactly did you say to them it get it fixed and check your profile ?
Hopefully this can sort my issue out as well?
Ive always been synching at 11mbs ... Recently it dropped to 9mbps and then 7mbps. My maximum attainable speed according to my router is 14mbps ... But because of my snr of 35db anything more than the current 11mbps I have is not attainable ...
So lots of factors of why not ... In my case they knew I had 11mbps before with no issue and this was a fault which they fixed ... All I told them was I synched at 11mbps and now I'm on 7mbps. My line stats are good for 11mbps and no reason for me to be at 7mbps. They checked profiles and fixed it
Downstream Line Rate (Kbps): 7167
Exactly same as yours, i have previously had 10mb with no problems just lately it is all over the show however my stats are :-
Line Coding(Trellis): On On
SNR Margin (dB): 78 36
Attenuation (dB): 425 246
Output Power (dBm): 0 127
Attainable Rate (Kbps): 13036 1116
Rate (Kbps): 7167 764
D (interleaver depth): 96 1
Delay (msec): 7.14 1.13
Literally just refreshed the paged and check my SNR margin change:-
SNR Margin (dB): 149 153
Something funky
And best off all net is dropping every 1 minute -_-, gaming is impossible
