My Arcade Cabinet build
Cool beans oomjan!
Busy planning a desktop arcade cabinet for myself.
Personally I prefer Retroarch, but usually I do "proper" jamma consoles.
I usually do embedded builds, or dedicated hardware myself though vs windows.
I can supply usb -> joystick/button controllers, and buttons/sticks if anyone wants (in Cape Town), as I have stock locally.
Thanks, but I already bought and received my Ipac2 last week ;)
What is your opinion about buying an old second hand arcade cabinet, and modifying it?
Always a good idea, especially if the cabinet is in decent condition. Not a lot are though.
Redoing the control panel probably a good idea, and using an LCD + scan line tool is an idea.
eg SLG3000, or the cheaper resistor + vga method.
Fantastic!
Never got around building mine. Got all the games and was last stuck on finding an affordable light gun to no avail and I left the project there.
Time Crisis and House of the Dead should be a must in my cabinet.
I considered picking up an old cab, but struggled finding one in good condition. Also the old cabs are huge and heavy! The wood for my build was dirt cheap. I have never done any woodworking in my life before, except a short stint in St6. So I just borrowed a jigsaw and router from a friend and built it myself.
Edit: Scott Hanselman has a nice blog post on his build using a second hand cabinet.
http://www.hanselman.com/blog/BuildingYourOwnArcadeCabinetForGeeksPart1TheCabinet.aspx
The wood for my build was dirt cheap, and I have never done any woodworking in my life, except a short stint in St6. So I just borrowed a jigsaw and router from a friend and built it myself.
You don't even need those tools, many places will cut all the pieces for you if you give them cad drawings. For those that fear power tools :D
Exactly! I had the sides of the cabinet done on a cnc router from a cad drawing. The one thing I wished I did was having the control panel laser cut from cad, especially the plexiglass, which was a b*tch to work with.
Well, that gives me some hope!
Ok, so for those of us who don't have CAD, what alternative can we use?
Great build! I have seen some option to use a Rasberry PI ? Anyone tried this before ?
