My Computer problem
cavedog
PTA
I have a problem with my operating system. Here is a screen shot of how my My computer screen looks.
And here is what happens if I want to open my C: and D:
They are both the same hard drive but it's partioned. Now everything was fine for about 7 months now it just suddenly starts to do this. This is strange cause my sisters laptop is doing exactly the same thing. Any 1 know how to fix or what I can do to try and fix it?
click browse and enter c:\windows\explorer.exe and tell it to use it always.
Yes if I right click on start and say explore I can use the menu on the right and browse like that
well - you need to find a way to reset your file association - I can't fathom what you did to your pc to confuse it like that...
did a bit of googling for you..
some things to try:
1 Open Start, Run and type regsvr32 /i shell32.dll
2. You will see a message DllRegisterServer and DllInstall in shell32.dll succeeded
Then try it again..
Another one:
enter the following commands in command prompt:
c:\> attrib -r -s -h autorun.inf
c:\> del autorun.inf
d:\> attrib -r -s -h autorun.inf
d:\> del autorun.inf
restart the pc
Let us know how it goes.
well, if you click folders at the top if will turn the window into Windows Explorer... shortcut - what happens when you do that and then select your C Drive from the left side bar??
Yes then I have to select the drive from the right then I can browse it normally. :confused:
I usually get that with my flash disk or external HDD, virus usually causes that and the only way I ever fixed it was to format. What does Google say?
A virus that passed Nod32 that I update like 15 times a day? :confused:
well in the first 3 programs you have on associations, 2 of them are virus spreading programs! try rapidfind.org instead.
yes that should work. was going to suggest that too, it should work.
