So I downloaded Linux tonight, Ubuntu, latest release.
I mounted the image and used the "install inside Windows" option.
Installation and configuring once booted into Linux took about 20 minutes to complete on my small Celeron M laptop.
Problems I'm facing at the moment:
I don't have an internet connection, because my Wireless network device isn't "picked up". Linux spat out something that it's using a "proprietary driver" for the device and that's about it.
So I hit F1 and started reading through the help files. It seems somehow that Linux is "disabling" my wireless device as I had to "switch on wireless" in Vista again after booting back to post here.
I can't use a cable, the router is just next to me in another room and I'm not about to buy a cable just to use Linux.
Is there any tips or steps you could give? I can't remember now exactly, but I don't see a "device manager" as I do in Windows with all the hardware. Is this because I didn't do a full installation?
When I use network tools or network manager in Linux I just see Wired Connection and Point to Point, both which are useless to me.
If I right click on the network icon top right and choose "edit wireless networks" the options don't enable to type or enter any info.
Lastly, I don't have any sound in Linux? My display is working properly as well as my resolution, but no sound or wireless.
Thanks for any help.
Another few things I forgot:
When booting into Linux from the options it says something along the lines of:
"look for Linux in hdd0,0: no wubildr" I can't remember exactly, but that's close, then it sits like that for about 2 minutes when finally it moves to a new screen then says "no valid filesystem found for hdd 80, use a Windows fdisk utility to repartition the drive, press Esc to skip this message" then after all the waiting Ubuntu loads.
LOL! I'll give it a shot again tomorrow. It looks a bit "plain", I miss the colourfulness of Windows when I'm in Linux, I love a theme, so you'll never see my pc's using Windows basic display
It's fast though, except when the hour glass thingy loads and loads in help files.
