MyMeg Advanced bundle on 2GB=2GB - is it possible?
I am able to purchase MyMeg Standard once-off data bundles on 2GB+2GB using the website. I am however not given options to purchase MyMeg Advanced once-off bundles on the website. Anyone have experience with this?
I recall there being some complicated rule that if you are on contract you can only buy a MyMeg Advanced once-off bundle if you already have an Advanced month-to-month bundle.
Here you go, VD's reply in post #10:
http://mybroadband.co.za/vb/showthr...-does-not-allow-for-advance-data-bundles-quot
Can you purchase a recurring Advanced bundle then on the 2GB+2GB special? I have someone interested in the deal but they will need up to 8 GB in a month.
Plan is to buy an additional Advanced 2.5 GB monthly recurring bundle and go OOB once the 4.5 GB data is finished (excl. night-owl) of course. This way they will only pay for what they use if usage is above 4.5 GB.
That's going to cost R469 + R149 = R618pm for the 6.5GB. (of which 2GB is only usable after midnight). Each additonal 1GB will cost R180 as well.
Tell them to get 8ta, 10GB for R199pm. Use at anytime of the day too.
Check for coverage first whichever they choose. Vodacom or 8ta.
I don't think you can have a Standard month-to-month bundle as well as an Advanced month-to-month bundle on the same number. OC or VD should be able to confirm this though.
Re getting 8ta this is for a friend in a remote place. There's only VC and MTN signal and MTN's contract length is prohibitive so VC it must be.
Then they are better off maybe spending R600 and getting four seperate 2GB+2GB packages if they need 8GB (anytime use). Forget about mymeg advanced. Vodacom will probably say that their systems do not allow one person to take the same package four times though...hehe
