Naks
- Jun 3, 2009
Boom! You're not holding back on this one, are you?
Congrats
Sadly those would be stock standard flat roof mounts. I've been breaking my head to find a cheaper solution too, but for some reason 30% angles are crazy expensive.Can you post a picuture on those mounting structures that cost R17.4K.
My plan is to install 16 panels.... at that rate I might be better off re-doing the roof to have the required pitch... Edit: read poorly... flat mounts... that is nutsSadly those would be stock standard flat roof mounts. I've been breaking my head to find a cheaper solution too, but for some reason 30% angles are crazy expensive.
Nice one @Naks - very impressive. 5kw should be good - we are a family of 4 and we get by with a 5kw Inverter and only 2.6kWp panels. So you should be good.
Would be interested to find out why Victron vs (insert other inverters) and also SolarMD vs (insert other batteries)?
Those concrete slabs look pretty much like lintels to me. Thanks for the pictures. Please post an after picture once it is installedBecause of the high winds we get here and the flat roof, they are putting down some concrete rails into which the panels will be secured.
Not sure how to explain it, but it will be clearer once it's all done.
CongratsAnother Victron install but a larger one than ours!
Do you know how the PV panels will be setup? Two strings of six PV panels?
not sure, will go take a look upstairs when they're done.
