Need advice on a smaller solar system...
Pho3nix
The Legend
On the toilet
Hi all,
I'll be moving in the next year or so but need something that will carry me through Stage ?? until then.
I don't want to spend R100K plus on this property and need advice on brands for following use-case.
Sun power during the day without a battery. I'll maybe add one in the future if my needs change but looking for a 3kw Hybrid Inverter and some help on panel sizing for 50x5w LED downlights, TV (120w) and 500w of laptop charging throughout the day, ideally also spinning my meter back as it's still the disc version.
Sunsynk doesn't seem to have the 3.6kw version anymore and don't think I need one any bigger.
I would rather go inverter and battery than inverter and panels.
  • Like
Reactions: rh1
Why not rather get an inverter plus battery mounted on a panel, mounted to the wall. Something like the blue nova kits. You can always take it with when you move.
This can definitely work. Issue is if I add another R20k for panels I’d be R50k in the hole and had I just committed to a starter Deye system it would be R70k odd.
I’ll give it some thought though. Really like this implementation.
Synapse a rebrand of the Kodak/Axpert inverters?
Sunsynk hybrids don't work without a battery.
A 5K Kodak Axpert-type with UPS or Luxpower SNA5000 is probably what you are looking for, it's cheap so it won't break the bank, reliable with local support.
Moving panels is a ball ache. Moving inverter + batteries is easy. If you just need to get through load shedding then start with batteries. Add panels after you move...
Seems I'm stuck with the following but I'll most likely request fewer panels :
Would the above get the job done?
At night I already have a Mecer for TV. Darkness doesn’t bother me that much.
What Mecer is it? Can always just add MPPT charge controller and panels to it if its big enough.
I have a 3kw mecer axpert inverter, 2x 305w panels and 4x 100aH LA batteries and it runs a lot of things without issue. (All lights, wifi/fiber, chest freezer, bar fridge laptop, TV, fish tank etc)
During sunlight hours the batteries stay full and it does 4h loadshedding without issue. Its normally the heating and cooling devices that nail you the rest are easier to run.
What you have above should give you a good amount of usability if you just do the lights and a couple of plug points. Just make sure you get enough panels to fit in the MPPT range for that inverter (125-425V.)
@Lupus I think you started on something similar?
I went the other way, inverter and batteries first, as storage is way more important during shedding.
Basically something like this would be a starting point as you'll have the storage, than slap on 1200w of panels and it'll be a small solar system.
So 3 of these should do, unless you get another charge controller for more panels.
That totals up up 34400 or so, plus you'll need the sundries that might add another 4k, and labour can be 4 to 9k.
Could go for this as a 5kw system, put on about 4kw of panels.
What can I do with this?
Can I connect 3/5 000 watt inverter and batteries, stove and geysor off?
What does DED Circuit stand for?
I opened this switch and it is already wired to the DB. Just need a red and black connection, I assume is a generator or inverter.
How do I test the total power being used through the DB currently?
That's not a bad price, the battery alone is R27k.
Is that inverter grid-tied or hybrid? That's probably the most important part. Grid-tied would be useless when the grid goes down...
Probably stands for dedicated circuit. Check to see if there's another DB somewhere.
As an example I have one in the pool pump enclosure, and another in the garage which runs the flat...
Looks like it's hybrid, not sure they'd include a battery with grid-tied solutions as you'd essentially be using the grid as your backup.
This isn't with an install though this is just the parts, so you'd still need to get an installer for it and that's probably going to be 5k. No panels either so for 5kw panels you're looking at another 30kish.
Sure but R12k for a 5 kW inverter + sundries is still decent. If it's hybrid then that's a very good deal...
Does say Hybrid
  • 1 x Growatt 5Kw Hybrid Inverter Es Model
Perhaps the Growatt is an Axpert clone, as I paid that for mine.
And it does only seem to be in their bundle deals, so perhaps they mark it down for the bundles.
Wasn't getting notifications for this thread. Thanks for the updates so far.
Was playing around on sizing and got to this. LuxPower is R1k more over the Growatt. I do like their setup though and will chat to SolarAdvise @Lupus
