Need advice on a smaller solar system...
Your Voltage on the PV panels should be higher then 150VDC.
Not sure about the min limit on inverter. Open circuit voltage approx. 49.xx volt.
Invertyer starts producing above 150VDC on mine.
That's not solar that's just the battery and inverter, speak to them they'll probably have installers, it'll probably be 5k to 9k
I know, there is a solar kit in eyeing ( panels + cables etc) and want to get a view on pricing for everything.
I’ll contact these okes tomorrow.
Absolutely. Much easier to store energy and can have 2 or 3 times your needs for those cloudy and rainy days. Goodbye Eskom
You'd need to pump the panels to fill them, but then again if you're only using 200kwh you'd be practically off the grid with even a 5kw system.
Probably stands for dedicated circuit. Check to see if there's another DB somewhere.
As an example I have one in the pool pump enclosure, and another in the garage which runs the flat...
Electricians sometimes do that for a stove or geyser, there was a time when it was legal to put such appliances on a dedicated circuit with no earth leakage.
Are we now banning Saturn and Uranus as well???
