Need advice on Explora 1 plus 2 single view HD decoders
pvs
Hi guys
I have limitation in my house with adding HB cables to the 2nd and 3rd TV so I would like to ask someone with knowledge of a similar setup if this is possible?
Yes it's possible as long as everything is connected accordingly
Thanks man, are you 100% sure about this? I'm only concerned as it is an Explora 1 and not the 2 and don't want issues with HB cables.
